Старый 04.03.2016, 23:11   #1
organicax: WMS Automatically create load at sales order entry
Источник: http://organicax.com/2016/03/03/wms-...s-order-entry/
Depending on the type of goods you work with you may ship each order as it comes in or try to consolidate shipments. There are a few different processes you can explore in warehouse management. If you want to create a load for each sales then you can look at a parameter called automatically create load at sales order entry.
Here is a quick look at how this works.
AX2012 R3 CU9
AX Build 7.0.1265.3015
Cheers
Lachlan
Filed under: Warehouse management
emeadaxsupport: Inconsistency between quantity in sales order and quantity in inventory transaction. Blog bot DAX Blogs 0 31.01.2015 17:11
atinkerersnotebook: Create Customer Sales Order Templates With Item Lists Blog bot DAX Blogs 0 02.06.2014 17:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 13:12.
