Старый 09.12.2015, 11:11   #1
mfp: X++ in AX7: Static members
Источник: http://blogs.msdn.com/b/mfp/archive/...c-members.aspx
You can now declare class member variables as static. The semantics are exactly the same as in C#; namely that all instances of the class will share the member, e.g. if one class sets the value, another class can get it.
Naturally; this should be used with care, but there are some really cool use cases, for example, implementing a singleton pattern in now much cleaner.
Example:
class MyClass
static MyClass singleton;
public MyClass getInstance()
if (!singleton)
singleton = new MyClass();
return singleton;
In previous versions of AX you could achieve similar behavior through the SysGlobalCache classes. The main functional difference between the two is that you can flush the SysGlobalCache classes. This is especially useful during test execution, where the test framework is automatically flushing the caches between each run to avoid state leaking from one test to another.
Static members will not automatically be flushed – you can of course create a flush() method yourself and hook it up to the SysTest::postInvokeTearDown() event.
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
mfp: X++ in AX7: Private and public members Blog bot DAX Blogs 12 10.12.2015 09:08
mfp: X++ in AX7: Type declarations can be 80 characters Blog bot DAX Blogs 0 08.12.2015 03:18
mfp: X++ in AX7: Finally and using Blog bot DAX Blogs 2 04.12.2015 12:45
mfp: X++ in AX7: The var keyword Blog bot DAX Blogs 43 04.12.2015 10:19
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 14:41.
