Старый 15.07.2015, 18:11   #1
bojensen: Import Label files ( ALD ) script, using SysLabelFile class
Источник: http://blogs.bojensen.eu/2015/07/15/...belfile-class/
If you have to import many Label files in different languages into AX 2012, you can use the script below.If the label file doesn’t exists, it will be created at the current level. This operation will overwrite any existing label different from file.     str path = @"C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAX\bin\Application\Appl\Standard\"; container files = ["axXXX","axYYY"…
Read more →
palleagermark: Quick import of new label files Blog bot DAX Blogs 0 01.07.2015 12:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Gareth Tucker: Scribe Insight and Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.05.2012 02:18
emeadaxsupport: How label flushing works under the hood Blog bot DAX Blogs 0 17.08.2010 16:05
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
Часовой пояс GMT +3, время: 18:51.
