Старый 30.05.2015, 04:24   #1
emeadaxsupport: Excel hangs while publishing/uploading data using the Excel Add-in for Dynamics AX
Источник: http://blogs.msdn.com/b/axsupport/ar...namics-ax.aspx
In a scenario, while trying to publish data/records using Excel add-in for Dynamics AX, issues like performance, hang/not responding, time out have been observed.
For Example, once clicked on ‘Publish All’ or ‘Publish Selected’ Excel goes to ‘not responding’ stage. This behavior gives an impression that the Publish action was not successful or it is abruptly hung.
Cause:
Behind the scenes, Excel is designed to automatically perform the ‘Refresh all’ action after completing ‘Publish All’ or ‘Publish Selected’ task.
Ideally, once the data from Excel is published, it is to amend that data in the database and then the Excel spins off a refresh action which fetches all the records (old and new) on Excel for the User’s visibility.
The larger the amount of data, the longer it takes for Excel to come back to life.
It is the ‘Refresh’ action which consumes additional time and resources. This leads to performance, Excel not responding/hang, time-out issues on Excel.
Resolution:
Shorten the time consumed by the Auto-Refresh action in Excel add-in. In order to do this:
  • Before doing the ‘Publish All’ or ‘Publish Selected’ task, use the built-in Filter functionality on Excel add-in.
  • Add a random filter criteria for any field e.g. ‘ZYX’ for ‘Journal batch number’ field. When Excel does the Refresh post publishing, this filter criteria will not
    return any results, as the value ZYX does not exists for this field in the database.
Hence in an environment where there is lot of data, it will certainly make sense to add a random filter (as in the above screen capture) as it will reduce the refresh time and Excel will still be active.
axnontechnical: How to view Microsoft Dynamics AX 2012 cube data in Microsoft Office Excel Blog bot DAX Blogs 0 09.03.2012 01:18
daxmusings: Importing Data to AX 2012 Using Excel Add-ins Blog bot DAX Blogs 0 19.01.2012 06:16
dynamics-ax: Microsoft Dynamics AX 2012 Excel Add-in Blog bot DAX Blogs 0 08.06.2011 08:12
emeadaxsupport: Solving various issues when using Export to Excel feature in Chart of Accounts Form (Microsoft Dynamics AX 2009) Blog bot DAX Blogs 0 15.07.2010 20:08
Часовой пояс GMT +3, время: 01:02.
