		#1 |
			emeadaxsupport: Return material adjustment (RMA) processing through the mobile device
			Источник: http://blogs.msdn.com/b/axsupport/ar...le-device.aspx
			============== This blog post assumes a working knowledge of the new Warehouse management module released in Microsoft Dynamics AX 2012 R3. The process of receiving a Return material adjust (RMA) using the new WMS mobile device functionality is very similar to processing an inbound transaction such as a purchase order. The following steps are intended as a walkthrough of the necessary setup and actions required to complete the process. They are completed against the USMF Contoso dataset on a CU8 installation. 1) Setup a Return order work template
 i. The first ii. Work type = Pick iii. Mandatory = Checked iv. Work class ID = Return v. The second vi. Work type = Put vii. Mandatory = Checked viii. Work class ID = Return ![]() ix. Close the form 2) Setup a Disposition code and link it to an inventory status
 i. Disposition code: The name of the disposition code. ii. Inventory status: An inventory status which will define the blocking strategy assigned to the returned item. iii. Work template code: The work template to which this disposition code should be linked. iv. Return disposition code: A traditional disposition code that contains the disposition action.
 i. Disposition code = Customer return ii. Inventory status = Available iii. Work template code = 51 Return Order iv. Return disposition code = 11 ![]() v. Close the form 3) Create a location directive to manage the Return order process in the warehouse
 i. Sequence number = 1 ii. Name = 51 iii. Work type = Put iv. Site = 5 v. Warehouse = 51 vi. Disposition code = Customer return (the disposition code must be specified or the location directive will not be found). ![]()
 i. Sequence number = 1 ii. From quantity = 1 iii. To quantity = 999,999 iv. Locate quantity = None ![]()
 i. Sequence number = 1 ii. Name = Put iii. Fixed location usage = Fixed and non-fixed locations iv. Strategy = None ![]()
 Create a menu item on the Mobile device
 i. Menu item name = RMA Process ii. Title = RMA Process iii. Mode = Work iv. Work creation process = Return order receiving ![]() v. Close the form 5) Add the new mobile device menu item to the mobile device
 i. Customer account = US-004 ![]() ii. Click OK to create the return orders
 i. Item number = A0001 ii. Site = 5 iii. Warehouse = 51 iv. Unit price = 5 v. Quantity = -1 ![]() vi. Copy the RMA number on the Return order header (General fast tab) 7) Open the Emulator in the AOT and receive the RMA to create the work
 i. User ID: = 51 ii. Password = 1 ![]()
 ![]() 8) Navigate back to the Return order and open the sales order to view the work
 ![]() Источник: http://blogs.msdn.com/b/axsupport/ar...le-device.aspx
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
