Старый 09.03.2015, 00:15   #1
emeadaxsupport: Change fixed asset group
Источник: http://blogs.msdn.com/b/axsupport/ar...set-group.aspx
The change fixed asset group function is commonly used to change the fixed asset group to another group, and consider that this function will not reclassify the asset from the accounting point of view. Changing the asset from group to another, it may use the same asset ID or rename it, and this does not generate any financial entries.
The path of change fixed asset group go to Fixed assets| Common| Fixed assets| Fixed assets
In order to change an asset group select an asset ID, and go to Maintain ribbon, and press Change fixed asset group
A dialog box opens to indicate the new group, and if you need to create new fixed asset number by renaming the old one. As shown in the below screen shot a dialog box opens indicate that rename the fixed asset.
There is another function to reclassify the asset group and considering the financial entries which known as Asset reclassification, this will be covered in another blog post.
emeadaxsupport: Scrap value of the fixed assets Blog bot DAX Blogs 0 12.02.2015 22:12
emeadaxsupport: How to perform a data center change (change of the physical location) where a SQL server 2008 R 2 cluster installation and MS Dynamics AX 4.0 is involved? Blog bot DAX Blogs 0 21.06.2014 19:19
emeadaxsupport: Error while importing a user group from the Active Directory into Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 22.05.2012 19:11
Shekhar: Dynamics AX 2009 – Import fixed asset journal lines for posting accumulated depreciation Blog bot DAX Blogs 0 17.01.2011 20:12
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
Часовой пояс GMT +3, время: 03:51.
