Старый 08.09.2014, 11:11   #1
bojensen: SSRS optional parameters settings
Источник: http://blogs.bojensen.eu/2014/09/08/...ters-settings/
Recently I had to create couple SQL Server Reports (SSRS) with optional parameters built in. It took me a while to refresh memory how this can be done. It was very simple to create reports and processes behind, but connecting these two were are little bit challenging – stored procedure was tested and worked fine,…
Read more →
bojensen: Reports in SSRS with Multi Value Parameters and NULL Values Blog bot DAX Blogs 0 08.09.2014 11:11
bojensen: Dialog fields and runtime lookups on SSRS Report parameters [Dynamics AX 2012] Blog bot DAX Blogs 0 24.01.2014 17:11
kamalblogs: SSRS Tip: Using invisible parameters in contracts – Dynamics AX 2012 Blog bot DAX Blogs 2 30.09.2013 17:50
bojensen: Dynamics AX: Calling a Custom Dynamics AX 2009 SSRS report and passing parameters – From X++ Blog bot DAX Blogs 0 08.04.2013 20:11
mfp: Optional parameters in C# and X++ Blog bot DAX Blogs 0 30.01.2010 00:05
Часовой пояс GMT +3, время: 10:15.
