Старый 03.07.2014, 00:11   #1
Dynamics AX Sustained Engineering: Now Supporting SQL Server 2014 Running on Microsoft Dynamics AX 2012 R2 CU7 and AX 2012 CU5
Источник: http://blogs.technet.com/b/dynamicsa...-2012-cu5.aspx
We are happy to announce support for SQL Server 2014 running on Microsoft Dynamics AX 2012 R2 Cumulative Update 7 and AX 2012 Cumulative Update 5. This means that all Dynamics AX 2012 versions are now supported with SQL Server 2014.
emeadaxsupport: Documentation collection: Inplace upgrade MS Dynamcis AX 2012 RTM --> AX 2012 R2 CU7 Blog bot DAX Blogs 0 22.06.2014 01:19
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: AX Content: How to install CU7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 12.11.2013 01:12
emeadaxsupport: Unexpected Compiler Errors installing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 07.11.2013 06:11
dynamicscpm: Currency translation for Microsoft Dynamics AX 2012 - Part 1: Setup (CU7 feature) Blog bot DAX Blogs 3 25.10.2013 02:12
Часовой пояс GMT +3, время: 05:27.
