Старый 02.07.2014, 23:16   #1
atinkerersnotebook: Create Composite Menus That Combine Functions From Multiple Areas
Источник: http://atinkerersnotebook.com/2014/0...ultiple-areas/
Originally posted on Dynamics AX Tip Of The Day:
As you use Dynamics AX more and more, you will find that you are sometimes using some functions from one area of the system, and then other features from another area in order to complete a task. Although everything is in the logical place, you may want to have a way to access everything at once from one menu. That’s not a problem though, you can easily create your own menu groups that meld multiple areas into one single location to make it easier to find everything that you want.
And you don’t even have to wait for lightening in order to make it come alive.
View the complete post here:
http://www.dynamicsaxcompanions.com/...Multiple-Areas
View original
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 09:35.
