Старый 22.06.2014, 21:16   #1
emeadaxsupport: Installation of MS Dynamics AX 2009 SP 1 on Windows XP SP 3
Источник: http://blogs.msdn.com/b/axsupport/ar...s-xp-sp-3.aspx
First of all be aware that Windows XP is out of MS product lifecycle (http://support.microsoftcom/lifecycle ) since April 2014 !
However, if you should face the following issue…
On a single Windows XP SP 3 workstation you receive the following error message when installing MS Dynamics AX 2009 SP 1:
Update "Service Pack 1 for Microsoft Dynamics AX 2009 Components (32 bit) (KB956568)" could not be installed. Fatal error 1603.
.. then check out the following Windows KB http://support.microsoft.com/kb/834484/en-us and make sure your work with local administrator permissions when you perform the installation!
emeadaxsupport: Multiple database data files, table partitioning using multiple file groups… and Microsoft Dynamics AX 2009 Blog bot DAX Blogs 3 04.10.2011 16:30
Часовой пояс GMT +3, время: 21:09.
