Старый 14.05.2014, 23:11   #1
axsa: Project Integration Walkthrough in Microsoft Dynamics AX 2012 R3
Источник: http://blogs.msdn.com/b/axsa/archive...x-2012-r3.aspx
With the Microsoft Dynamics AX 2012 R3 release, Microsoft Project Integration for Dynamics AX is now a client based integration model. This makes the integration prerequisites and the configuration process much simpler than in previous versions of AX. In order to configure Project Integration you only need to follow the simple process outlined below.
...(read more)
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
Часовой пояс GMT +3, время: 10:45.
