Старый 16.04.2014, 15:11   #1
atinkerersnotebook: Copy Data Between Companies Quickly Using The Data Import Export Framework
Источник: http://atinkerersnotebook.com/2014/0...ort-framework/
Originally posted on Dynamics AX Tip Of The Day:
The Data Import Export Framework module is not just for getting data in and out of Dynamics AX through import and export files, it also has a nifty feature that allows you to copy data within your companies, so if you are configuring a new legal entity for testing or production purposes, and want to populate it with information from another existing company, you can replicate the data in a matter of minutes.
It’s like having your own personal Sketch-A-Graph, but not as much fun…
View original 383 more words
atinkerersnotebook: Copy Data From One Partition To Another Using The Data Import Export Blog bot DAX Blogs 0 03.04.2014 15:11
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
Часовой пояс GMT +3, время: 07:45.
