Старый 06.03.2014, 10:49   #1
Anitha Roy is offline
Anitha Roy
need to generate Prepayment invoice for a purchaseorder
Hi Friends,
Hope everybody is doing well..
I'm facing this issue from last one week if anybody know the solution for this please help me out.(AX2012 R2)
I'm selecting a purchorder where i should generate a prepayment invoice for that thorugh code(X++).
I tried the call menuitem of PurchFormLetter_PrepayInvoice_Action but pop up a form(vendeditinvoice form) which i dnt want.Please help me out
Thank you..
Последний раз редактировалось Anitha Roy; 06.03.2014 в 10:54.
Старый 06.03.2014, 16:01   #2
dech is offline
dech
Аватар для dech
650 / 352 (13) ++++++
Hi there.
I think, you should provide PurchFormLetter class with correct Args parameters.
When you call PurchFormLetter_PrepayInvoice_Action menu item you have to pass a record.
Also don't forget about caller form.
// no comments
Старый 12.03.2014, 22:22   #3
Anitha Roy
Hi Dech,
but the problem is im doing it through batch job.so while calling this menu item(PurchFormLetter_PrepayInvoice_Action Item ) we will pop up a form called vendeditinvoice which i dont want..
Thanks for the reply
emeadaxsupport: The Description in the Free text invoice lines changes after the invoice is posted or when printing a Free Text Invoice in AX2012 Blog bot DAX Blogs 0 16.12.2013 19:12
emeadaxsupport: Can't find the packing slip during invoice matching or is the invoice form not showing any order lines? Blog bot DAX Blogs 0 11.06.2012 22:13
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
Shekhar: Invoice journal linked with Purchase order Blog bot DAX Blogs 0 31.05.2010 22:05
Часовой пояс GMT +3, время: 13:11.
