Старый 24.01.2014, 01:15   #1
Malaysia: How to print the SSRS report in dynamics ax 2012 from code.
Источник: http://axmas.blogspot.com/2014/01/ho...namics-ax.html
SrsReportRun srsReportRun; // initiate the report. srsReportRun = new SrsReportRun ("InventTruckTransactionReport.PrecisionDesign1"); srsReportRun.init(); srsReportRun.reportCaption("InventTruckTransactionReport.PrecisionDesign1"); // set parameters name, value. srsReportRun.reportParameter("TruckTransDS_JournalId").value("000161_070"); // suppress the dialog srsReportRun.showDialog(false); if( srsReportRun ) { // run the report srsReportRun.executeReport(); }
kamalblogs: SSRS Tip: Using invisible parameters in contracts – Dynamics AX 2012 Blog bot DAX Blogs 2 30.09.2013 17:50
kamalblogs: SSRS tip: Take care that VS and AX client are in the same layer for SSRS – Dynamics AX 2012 Blog bot DAX Blogs 0 09.09.2013 16:11
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Security How-To' Blog bot DAX Blogs 0 13.12.2012 01:13
Часовой пояс GMT +3, время: 18:39.
