#1 |
Leon's CRM Musings: Dialog Lookup Values For Common Entities
Источник: http://leontribe.blogspot.com/2014/0...-entities.html
============== One feature of dialogs is the ability to prompt the user for a record to interact with i.e. prompt for a lookup response. The Reference Entity and Reference Field are two of the least intuitive features of CRM so I thought I would write an article on how they work and some good values to use for them. How They Work Essentially, the two fields are used to define a lookup which already exists in CRM so it can be presented to the user, during the dialog, and receive a value. So, if you are wanting to capture, for example, a Contact record from the user, you could use the Primary Contact lookup (Reference Field) on the Account entity (Reference Entity). This will allow the dialog to prompt the user for a Contact lookup so a Contact can be chosen. Once this is explained, it actually makes a lot of sense or, at least, is quite easy to use. Typical Values for the Common Entities According to the Audit Settings, these are the Common Entities, with some suggested settings for the dialog:
A composite lookup is a lookup which allows the user to select a record from more than one entity. So, in the example above, the Campaign Response-Parent Campaign lookup allows the user to select from either Campaigns or Quick Campaigns. The Customer lookup is also a special, hard-coded lookup which allows the user to select either an Account or Contact. This can also be used in a dialog if an Account/Contact is required e.g. for the client associated to a Case. Typical Values for Sales Entities For the sales entities we have:
For the marketing entities we have:
For the customer service entities we have:
Once explained, the configuration of a lookup response for dialogs is not too difficult. With the above examples, most dialogs can be configured without the headache of having to trawl through CRM to find the right lookup for the job. Источник: http://leontribe.blogspot.com/2014/0...-entities.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
