Старый 02.01.2014, 22:11   #1
Pawan's Ax blog: How To Iterate all the fields of a table in Ax2012 using x++ code.
Источник: http://pawansaxblog.blogspot.com/201...-table-in.html
In my recent implementation I was having one requirement in this I had to retrieve all the fields of a table and then on certain criteria I had to update these fields in another table. I could do this sing If-else condition but it requires lot of code. So I did it in a better way.
public void updateEstimatesFromCase()
CopyEstimates copyEstimates;
SysDictTable dictTable;
SysDictTable caseDictTable;
SysDictTable activityDictTable;
SysDictField dictField;
SysDictField caseDictField;
SysDictField activityDictField;
FieldId fieldId;
FieldId caseFieldId;
FieldId activityFieldId;
CaseDetailBase caseDetailBase = caseDetailBase::find(this.caseId());
CaseTimeEstimatesTable caseTimeEstimatesTable;
ActivityTimeEstimatesTable activityTimeEstimatesTable;
ActivityTimeEstimatesTable buffer;
select firstonly caseTimeEstimatesTable
where caseTimeEstimatesTable.CaseDetailBase == caseDetailBase.RecId;
select firstOnly activityTimeEstimatesTable
where activityTimeEstimatesTable.smmActivities == this.smmActivities;
buf2Buf(buffer,activityTimeEstimatesTable);
if (activityTimeEstimatesTable.RecId)
activityTimeEstimatesTable.selectForUpdate(true);
activityTimeEstimatesTable.update();
caseDictTable = new SysDictTable(caseTimeEstimatesTable.TableId);
dictTable = new SysDictTable(this.TableId);
fieldId = dictTable.fieldNext(0);
while (fieldId)
dictField = dictTable.fieldObject(fieldId);
if (dictField.isSql() && !dictField.isSystem())
activityTimeEstimatesTable.smmActivities = this.smmActivities;
if (this.(fieldId) && fieldId != fieldNum(copyEstimates, smmActivities))
caseFieldId = fieldName2id(tableNum(CaseTimeEstimatesTable),dictField.name());
activityFieldId = fieldName2id(tableNum(ActivityTimeEstimatesTable),dictField.name());
activityTimeEstimatesTable.(activityFieldId) = caseTimeEstimatesTable.(caseFieldId);
else
activityTimeEstimatesTable.insert();
fieldId = dictTable.fieldNext(fieldId);
Pawan's Ax blog: How To Flush label Files Using x++ code. Blog bot DAX Blogs 0 20.12.2013 16:11
Pawan's Ax blog: Code to copy data from one table to another even though the tables are different provided the field names are same. in Ax2012 Blog bot DAX Blogs 0 09.12.2013 00:14
axhelper: Add Fields to a table, using code_not the AOT In Dynamics Ax Blog bot DAX Blogs 0 04.10.2010 11:05
Часовой пояс GMT +3, время: 16:46.
