Старый 31.12.2013, 02:16   #1
axStart: Call non AX reports on SSRS in AX 2012
Источник: http://www.axstart.com/call-non-ax-r...srs-in-ax-2012
There are scenarios, that report generated in SQL Reporting Builder, or Visual Studio that are completely not working with AX SSRS reporting integrations. Examples like reports that use non AX data or, are simply to complex building it in AX. But it would be nice to have these reports integrated in the Menu Structure of AX. Even some authorization on top of it would be nice.
So how can we glue a menu item to an SSRS report that does not belong to AX. The trick is using a class. The main method of this class should look like this:
public static void main(Args args)
#define.reportName(‘report_name’)
SRSServers srsServers;
SRSReportServerConfiguration reportServerConfiguration;
select   firstOnly srsServers where srsServers.IsDefaultReportLibraryServer;
reportServerConfiguration =   SrsFrameworkServiceHelper::createSRSReportServerConfiguration(srsServers);
if(websession())
websession().redirectURL(reportServerConfiguration.reportManagerURL()+’/Pages/Report.aspx?ItemPath=/’+   reportServerConfiguration.reportFolder() +’/'+#reportName);
else
infoLog.urlLookup(reportServerConfiguration.reportManagerURL()+’/Pages/Report.aspx?ItemPath=/’+   reportServerConfiguration.reportFolder() +’/'+#reportName);
You could add a menu item Action to it and use this menu item on the menu.
So will this work ; Yes. But you have to deal with security on SQL yourself. In case the class is running client site it is with the current user security, is it running server site, it is with the service account of the AOS.
Старый 31.12.2013, 14:21   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Не осознал в предновогодней суете а собственно чем просто вызов браузера с url то не устраивает? Там и безопасность на уровне пользователей можно настроить...
Axapta book for developer
Старый 31.12.2013, 16:43   #3
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Сообщение от MikeR Посмотреть сообщение
infoLog.urlLookup это и делает.
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 20:41.
