Старый 01.12.2013, 16:15   #1
bojensen: Loop through Data Source
Источник: http://blogs.bojensen.eu/?p=4764
Here is a simple way to traverse a data source: A form datasource has two methods getFirst() and getNext(), which enable you to traverse through the records in a grid. Examples: Use following code to traverse all shown lines in a grid: for ( custTrans = CustTrans_DS.getFirst(); custTrans; custTrans = CustTrans_ds.getNext() ) { totalAmountMST += […]
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
bojensen: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] | Sreenath Reddy G – Dynamics AX Consultant’s Blog Blog bot DAX Blogs 0 15.03.2013 17:11
axStart: Change data on a data source on a Form Blog bot DAX Blogs 0 04.09.2008 15:05
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 00:19.
