Старый 25.11.2013, 21:11   #1
emeadaxsupport: How to setup SEPA Credit in AX2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...ax2012-r2.aspx
Please find attached a document explaining how to configure SEPA Credit in AX2012 R2. The same information applies to AX2012 RTM
This document was written by Petra Allegrini from our German support team
As listed in http://blogs.msdn.com/b/axsupport/ar...mber-2013.aspx we recommend you to install KB 2902097 to act as a baseline for this setup. KB 2902097 is planned to be released on November 30th 2013
emeadaxsupport: How to setup SEPA Direct Debit in AX2012 R2 Blog bot DAX Blogs 0 25.11.2013 21:11
emeadaxsupport: AX Content: How to install CU7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 12.11.2013 01:12
emeadaxsupport: Invitation to EMEA webinar - How to setup SEPA in Dynamics AX 2012 and an overview of published hotfixes Blog bot DAX Blogs 0 17.10.2013 17:11
emeadaxsupport: How to set up SEPA Credit transfers in AX2012 Blog bot DAX Blogs 0 01.05.2013 16:12
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
Часовой пояс GMT +3, время: 23:37.
