Старый 24.03.2004, 10:54   #1
paucer is offline
paucer
? filter on a form - how?
I need add some functionality to a form, but only when filtering is enabled.
How can i check this?
Form's datasource has mathod filter(), but it seems this method isn't invoked, when user press filter shortcut button or press CTRL+F3 or filter from context menu. I tried to use prompt() method, but it isn't invoked when filtering is started via context menu. And i need do additional calculation, when the filter is enabled or is being disabled - removeFilter() works ok.
So how can I manage filtering?
At least i must know if fitering is turned on or off.
DeniZone: How to tell if a form was opened with 'Go to main table' function Blog bot DAX Blogs 0 17.02.2009 19:05
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
hariprasadp: Grid Filter while open a form in Dynamics AX Blog bot DAX Blogs 0 07.05.2008 15:05
axaptafreak: Automatically open grid filter when opening form Blog bot DAX Blogs 2 20.06.2007 18:36
Часовой пояс GMT +3, время: 08:54.
