Старый 20.09.2013, 13:11   #1
palleagermark: Moving labels from AX 2012 R2 to RTM via XPO's
Источник: http://www.agermark.com/2013/09/movi...r2-to-rtm.html
If you make an xpo export from AX 2012 R2 with labels, you'll get an error if you select "Show details" during import on AX 2012 RTM.
For this to work, you need to go through the xpo file and remove lines refering to "Partition":
5637144576
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
DAX: A sneak peek tour: 4 Business Benefits of Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 03.12.2012 11:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 05:23.
