Старый 22.07.2013, 21:12   #1
dynamicscare: Data Import/Export Framework: Steps for a simple file import
Источник: http://dynamicscare.com/blog/data-im...e-file-import/
Importing A Simple File utilizing the Data Import/Export Framework. The Data Import/Export Framework for AX 2012 is a very powerful tool that allows for a more simplified way to import Master Data.  The Framework allows for imports of Files and ODBC connections, but for this post I will be focusing on a file import.  Microsoft [...]
dynamics-coe: Dynamics AX Export/Import Framework for Vendor balance migration Blog bot DAX Blogs 0 22.05.2013 20:13
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework (Old name - Data Migration Framework) is now available on Information source Blog bot DAX Blogs 0 16.03.2013 15:12
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 25.03.2008 03:58
Часовой пояс GMT +3, время: 01:18.
