Старый 26.04.2013, 00:13   #1
emeadaxsupport: Dynamics AX 2012 Services: Applying a XSL transform to a AIF XML document (Outbound Port) selects each value in the whole document instead of the elements specified
Источник: http://blogs.msdn.com/b/axsupport/ar...specified.aspx
For example, the following XML document is created for a customer sales invoice.
{7F99293C-0469-4D50-8489-0C5E5CF2741C}
http://schemas.microsoft.com/dynamics/2008/01/services/SalesSalesInvoiceService/read
USD
10
1104
2008-06-27
en-us
1104
2008-06-27
101076
SalesInvoice
en-us
And you add the following XSL transform on the outbound port:
It produces the following result:
{F12B1037-B6DC-4BB9-BAD3-B4236422839E}http://schemas.microsoft.com/dynamic...esInvoiceen-us
You would expect the following result:
10
Resolution:
The attached XSL was not taking into account the namespaces within the XML schema. The following XSL is correct. Please use this as a reference for building XSL transforms for our Dynamics AX 2012 documents. There is no product issue here.
<span style="color: #0000ff; font-family: Consolas; font-size: x-small;"><span style="color: #0000ff; font-family: Consolas; font-size: x-small;">
emeadaxsupport: Install multiple instances of Reporting Services on the same computer (for use with Microsoft Dynamics AX) [AX 2012] Blog bot DAX Blogs 0 14.09.2012 03:21
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting Services – Scale-out deployments Blog bot DAX Blogs 0 28.11.2011 00:14
emeadaxsupport: Microsoft Dynamics AX 2012: Install multiple instances of Reporting Services extensions on the same machine Blog bot DAX Blogs 0 22.09.2011 20:11
Часовой пояс GMT +3, время: 01:45.
