Старый 18.03.2013, 17:11   #1
bojensen: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012]
Источник: http://blogs.bojensen.eu/?p=4675
  In this walkthrough, you use a report data provider (RDP) class with business logic to process data and then display the outcome of the business logic on a report. An RDP class is an X++ class that is used to access and process data for a Reporting Services report. The options for a data [...]
bojensen: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] | Sreenath Reddy G – Dynamics AX Consultant’s Blog Blog bot DAX Blogs 0 15.03.2013 17:11
bojensen: Dynamics AX 2012 error when running SSRS-reports just after deleting a table field from report’s temporary table – Addicted2AX / Addicted2SQL Blog bot DAX Blogs 0 09.01.2013 17:11
dax-lessons: Display Barcode in SSRS report [Dynamics AX 2012, X++] Blog bot DAX Blogs 0 15.05.2012 18:11
Часовой пояс GMT +3, время: 11:38.
