Старый 22.12.2012, 03:14   #1
emeadaxsupport: Upgrading from AX 2012 / AX 2012 Feature Pack to AX 2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
The new upgrade guide has been released at http://www.microsoft.com/en-us/downl....aspx?id=14599 and has very detailed steps on performing an in-place upgrade of AX 2012/AX 2012 FP to AX 2012 R2. Download a copy and ensure it is dated December 2012.
It talks about all the steps you need to take, starting from creating a test system first and restoring a copy of your production database on to it and onwards. It suggests following the steps in the order given and makes several suggestions and recommendations to ensure a good upgrade path.
emeadaxsupport: Error when upgrading to AX 2012 Feature Pack: The UPDATE statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId" Blog bot DAX Blogs 0 20.07.2012 00:11
Dynamics AX Sustained Engineering: Servicing of Dynamics AX 2012 and Dynamics AX 2012 Feature Pack Blog bot DAX Blogs 0 08.05.2012 23:12
Часовой пояс GMT +3, время: 22:34.
