Старый 08.12.2012, 05:53   #1
bojensen: Simple Steps To Create Number Sequence In Ax2012
Источник: http://blogs.bojensen.eu/?p=4596
how to create number sequence in AX2012 It is same as like as we know in Ax2009 but small steps is added in AX2012.don’t worry just follow the below steps simply we will get number sequence in AX2012. We will Take a EDT name as “Car Id” and create in number sequence.For that first we [...]
emeadaxsupport: Where is the System ID number sequence used? Will it run out? Blog bot DAX Blogs 0 25.05.2011 00:11
crminthefield: How to Create a Simple Webpage Leveraging The CRM 2011 IOrganizationService Web Service Blog bot Dynamics CRM: Blogs 0 19.05.2011 02:11
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
X++ Create company: генерация companyId c помощью Number Sequence DmitrySincerity DAX: Программирование 20 04.02.2009 14:09
daxcoder: Number Sequence Framework Part I Blog bot DAX Blogs 0 31.01.2008 15:00
Часовой пояс GMT +3, время: 18:01.
