Старый 26.11.2012, 11:11   #1
Malaysia: Using a form for building a lookup
Источник: http://axmas.blogspot.com/2012/11/us...ng-lookup.html
1. In the AOT, create a new form named CustLookup. Add a new data source with the
following properties:
Property Value
Name CustTable
Table CustTable
Index AccountIdx
AllowCheck No
AllowEdit No
AllowCreate No
AllowDelete No
OnlyFetchActive Yes
2. Change the properties of the form's design as follows:
Property Value
Frame Border
WindowType Popup
3. Add a new Grid control to the form's design, with the following properties:
Property Value
Name Customers
ShowRowLabels No
DataSource CustTable
4. Add a new StringEdit control to the grid, with the following properties:
Property Value
Name AccountNum
AutoDeclaration Yes
DataField AccountNum
5. Add a new ReferenceGroup control to the grid with the following properties, right
after the AccountNum:
Property Value
Name Name
ReferenceField Party
6. Add one more StringEdit control to the grid with the following properties, right
after the Name:
Property Value
Name Phone
DataMethod phone
7. Add a new ComboBox control with the following properties to the end of the
Customers grid:
Property Value
Name Blocked
DataField Blocked
8. Override the form's init() method with the following code:
public void init()
super();
element.selectMode(AccountNum);
9. Override the form's run() method with the following code:
public void run()
FormStringControl callingControl;
boolean filterLookup;
callingControl = SysTableLookup::getCallerStringControl(
element.args());
filterLookup = SysTableLookup::filterLookupPreRun(callingControl, AccountNum, CustTable_ds);
super();
SysTableLookup::filterLookupPostRun(filterLookup, callingControl.text(), AccountNum, CustTable_ds);
10. Finally, override the init() method of the CustTable data source with the
following code:
public void init()
Query query;
QueryBuildDataSource qbds;
QueryBuildRange qbr;
query = new Query();
qbds = query.addDataSource(tableNum(CustTable));
qbr = qbds.addRange(fieldNum(CustTable,Blocked));
qbr.value(queryvalue(CustVendorBlocked::No));
this.query(query);
11. The form in the AOT should look similar to the following screenshot:
12. Locate the CustAccount extended data type in the AOT, and change its property
as follows:
Property Value
FormHelp CustLookup
13. To test the results, open Sales and marketing | Common | Sales orders | All sales
orders, and start creating a new sales order. Notice that now the Customer account
lookup is different, and it includes only active customers:
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Kashperuk Ivan: Lookup form returning more than one value Blog bot DAX Blogs 0 29.01.2010 18:05
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Часовой пояс GMT +3, время: 07:16.
