Старый 30.08.2012, 17:11   #1
emeadaxsupport: Update has been cancelled because of an error
Источник: http://blogs.msdn.com/b/axsupport/ar...-an-error.aspx
We have come across an issue where users are getting the following error message when trying to do any posting(Sales Order, Purchase Order, Journal) in Microsoft Dynamics AX 2012
F.e This error message is produced when doing a Sales Order invoicing posting
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.ErrorException' was thrown.
at Dynamics.Ax.Application.FormletterService.Run() in FormletterService.run.xpp:line 174 at Dynamics.Ax.Application.FormletterService.Postsalesorderinvoice(SalesFormLetterInvoiceContract _contract) in FormletterService.postSalesOrderInvoice.xpp:line 14 at FormletterService::postSalesOrderInvoice(Object , Object[] ) Or from a journal posting(Where the Development option ‘Execute business operation in CIL’ has been unchecked)
“Error message: Update has been canceled because of an error
Posting has been canceled”
The error only occurs in certain legal entities, in other legal entities the postings goes through with no problem
What we found is that we could resolve this error by opening up the table ‘DimensionAttributeValueCombinationStatus’ in the AOT and ensure that the field ‘Is Valid’ is checked.
If unchecked, try to check it and see if you are able to post. We have seen a certain scenario when renaming a dimension the 'IsValid' field in ‘DimensionAttributeValueCombinationStatus’ is incorrectly cleared for the current company when disabling it for another company
emeadaxsupport: Error when upgrading to AX 2012 Feature Pack: The UPDATE statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId" Blog bot DAX Blogs 0 20.07.2012 00:11
Часовой пояс GMT +3, время: 19:21.
