Старый 24.05.2012, 01:13   #1
emeadaxsupport: Microsoft Dynamics AX 2012: Workflow Basic Settings Form Has Missing Text Boxes
Источник: http://blogs.msdn.com/b/axsupport/ar...ext-boxes.aspx
When trying to create a new workflow configuration, you may find that text boxes are missing from the Properties form when you try to modify the basic settings. You are therefore unable to create a valid workflow configuration as you cannot input text for the submission instructions and other mandatory fields.
(Screenshot showing Properties form with submission instructions text box missing)
You will see errors similar to those in the screenshot below, stating that text must be defined in the default language before the workflow is valid.
The issue of the missing text boxes will occur if there is a problem with the default language. You will need to correct this and ensure you have selected a valid language ID, for which a licence exists in your system.
The default language is defined in one of two places and this depends on whether you’re creating an organization-wide workflow, or a company-specific workflow (see the following TechNet article for a list of the different workflow types and their scope - http://technet.microsoft.com/en-us/l.../dd362043.aspx)
For Organization-wide workflows – navigate to System Administration > Setup > System parameters and check the System Language.
For Company-specific workflows – navigate to Organization Administration > Setup > Organization > Legal Entities and check the Language field:
--author: Doug Bartley
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Swiss Army Knife Blog bot Dynamics CRM: Blogs 1 19.04.2012 08:20
emeadaxsupport: 3. Solving Fill Utility errors on Microsoft Dynamics AX 2012 - Error executing code: Wrong argument types for comparison Blog bot DAX Blogs 1 08.02.2012 08:53
dynamics-ax: Microsoft Dynamics AX 2012 - Launch Event, Training Plans & WPC 2011 Blog bot DAX Blogs 0 13.07.2011 22:11
Часовой пояс GMT +3, время: 18:12.
