Старый 17.05.2012, 06:13   #1
emeadaxsupport: SRS Report CustAccountStatement is hanging with Suspended Process in AX 2012 CU-2
Источник: http://blogs.msdn.com/b/axsupport/ar...2012-cu-2.aspx
We recently came across an issue on Microsoft Dynamics AX 2012 RTM CU-2. When we try to run the report "Accounts receivable\reports\external\customer account statement", AX ends up hanging. This happens in every environment if I just choose a customer account and leave all else as default.
The reason we found was:
In \Classes\SrsReportRunRdpPreProcessService, executeWithContract method, there are some code shown below, there is a UserConnection ttsBegin and UserConnection ttsCommit pair embedded in global ttsBegin and ttsCommit pair, this makes the database write operation to hang.
 // switch company to that user.
 changecompany(companyId)
 // check if any pre-processing id already exists, if yes, then call cleanup, this will take care of cleaning up left over data.
 if(_preProcessedRecId)
 this.cleanUp(_preProcessedRecId, reportContract.parmRdpName());
 // starting a default transaction, since some RDP classes do delete as part of their code and they dont have a explicit ttsbegin/ttscommit.
 // they were relying on the old behvior of SrsReportRunRdpPreProcessService class starting a default ttsbegin/commit.
 ttsBegin;
 // We start transaction before calling processReport. By doing so, all data
 // inserted by RDP into table will have the same transactionId.
 // Always use a UserConnection. The service is currently running on RPC call and hence if outer transaction exists we dont want it to be used.
 userConnection = new UserConnection(true);
 userConnection.ttsbegin();
 // set user connection on RDP class.
 rdpInstance.parmUserConnection(userConnection);
 // call processReport
 rdpInstance.processReport();
 // now create a entry in table with report name etc.
 // transactionId will be same as the one used in processReport().
 preProcessedTable = SrsReportPreProcessedDetails::create(reportContract.parmRdpName(), userConnection, _isPreviewData);
 // commit the transaction.
 userConnection.ttscommit();
 ttsCommit;
To workaround, the suggestion is to comment out those inner transactions, so that code looks as given in the highlighted sections below:
 ttsBegin;
 // we dont want it to be used.
 //userConnection.ttsbegin();
 //userConnection.ttscommit();
 ttsCommit;
--author: Mansour Yahya Mohamad
Последний раз редактировалось Poleax; 17.05.2012 в 15:13. Причина: оформление
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting extensions: Error System.Security.Permissions.EnvironmentPermission while running report Blog bot DAX Blogs 0 02.02.2012 21:11
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
Часовой пояс GMT +3, время: 01:04.
