Старый 12.05.2012, 01:11   #1
crminthefield: Script Error “The system cannot find the file specified” when using Microsoft Dynamics CRM 2011.
Источник: http://blogs.msdn.com/b/crminthefiel...-crm-2011.aspx
I have worked with a couple customers lately that would receive a script error when opening and navigating around Microsoft Dynamics CRM 2011. The first sign of the issue was an “Error on Page” message on the bottom left hand corner of the IE window. When they would attempt to browse to another area or close the form the following “Microsoft Dynamics CRM has encountered an error” message was thrown.
To see details of the script error you are able to click the link “View the data that will be sent to Microsoft” and the details will be displayed in another window.  For this specific issue the following script error report was provided stating that “The system cannot find the file specified”.
1.0
   The system cannot find the file specified.
   1
   /_static/_common/scripts/main.js?ver=-863096087
   /main.aspx?etc=2&extraqs=%3f_gridType%3d112%26etc%3d112%26id%3d%257b6VCED6531-C5W3-R083-A86T-015676G13257%257d%26rskey%3d949894547&pagetype=entityrecord
   anonymous($p0,$p1){try{if(!IsNull($p0)){var$v_0=String.format("Timestamp:Loaded={0},Updated={1},Saved={2}{3}{4}",this.$X_3.toString(),!IsNull(this.$J_3)?this.$J_3.toString():(newDate).toString(),!IsNull(this.$R_3)?this.$R_3.toString():"",this.$2_3,$p0);th
    anonymous($p0,$p1){try{if(!IsNull($p0)){var$v_0=String.format("Timestamp:Loaded={0},Updated={1},Saved={2}{3}{4}",this.$X_3.toString(),!IsNull(this.$J_3)?this.$J_3.toString():(newDate).toString(),!IsNull(this.$R_3)?this.$R_3.toString():"",this.$2_3,$p0);this.get_element().setAttribute(this.$P_3,$v_0)}}catch($$e_1_0){var$v_1=String.format("Timestamp:Loaded={0},Updated={1},Saved={2}{3}{4}",this.$X_3.toString(),this.$J_3.toString(),!IsNull(this.$R_3)?this.$R_3.toString():"",this.$2_3,$p1);this.get_element().setAttribute(this.$P_3,$v_1)}this.get_element().save("RVItems")}<strong>
    anonymous($p0){this.$X_3=this.$17_3;var$v_0=this.$g_3($p0);$v_0=this.$12_3($v_0);this.$G_3($v_0,$v_0);for(var$v_1=0;$v_1
Microsoft Dynamics CRM Team Blog: Fast, Efficient Growth for Project Management Solution - Case Studies Blog bot Dynamics CRM: Blogs 0 01.02.2012 03:18
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 03.08.2011 09:11
Microsoft Dynamics CRM Team Blog: Testing your Microsoft Dynamics CRM 2011 Apps Blog bot Dynamics CRM: Blogs 0 01.12.2010 03:14
Удаленная работа с CRM и расширеный поиск ASheff Dynamics CRM: Разработка 64 04.06.2010 17:44
Часовой пояс GMT +3, время: 05:39.
