Старый 27.04.2012, 16:11   #1
ax-erp: The backup set holds a backup of a database other than the existing database
Источник: http://microsoft-dynamics-ax-erp.blo...-database.html
This error message appear when I tried to restore an SQL 2K SP4 db into SQL 2005, using SQL Server Management Studio.
Although I have specified overwrite existing database, the error message still appear.
So I run transact-sql statement instead :
restore filelistonly
from disk = 'D:\SQL Backup\sourceDB.bak'
GO
--This will show the logical file name needed in the operation below
restore database targetDB
WITH MOVE 'sourceDB_Data' TO 'D:\SQLDATA\targetDB_Data.MDF',
MOVE 'sourceDB_Log' TO 'D:\SQLDATA\targetDB_Log.ldf',
REPLACE,STATS
GO
-- The option with replace is mandatory as it will overwrite existing database. With stat will show the operation progress
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 14:52.
