#1 |
emeadaxsupport: In Microsoft Dynamics AX 2012 the Default account setup Lookup form is listing Main Accounts from all Company Accounts rather than just active Company Accounts
Источник: http://blogs.msdn.com/b/axsupport/ar...-accounts.aspx
============== We came across an issue recently where the “Default account setup" Lookup form is listing Main Accounts from all Company Accounts. We are using Microsoft Dynamics AX 2012 CU-2. The selection in some queries brought unexpected results. For example: Under Accounts payable > Setup > Vendors > Vendor groups. Then select one Vendor and click “Default account setup”. The look up will then list the Main Accounts from all Company Accounts instead of only the current active Company Account. The results are derived as a result of the where clause selection in \Data Dictionary\Tables\VendDefaultAccounts\Methods\notSelectedLedgerAccountList method We worked around the issue by changing one line of code in the notSelectedLedgerAccountList method from ... outer join RecId from dimAttributeValueCombo where dimAttributeValueCombo.DisplayValue == mainAccount.MainAccountId && dimAttributeValueCombo.LedgerDimensionType == LedgerDimensionType::DefaultAccount ... to: ... outer join RecId from dimAttributeValueCombo where dimAttributeValueCombo.MainAccount == mainAccount.RecId && dimAttributeValueCombo.LedgerDimensionType == LedgerDimensionType::DefaultAccount ... For completeness, the full method code and modified line is shown in the highlight below: public server static List notSelectedLedgerAccountList() { MainAccount mainAccount; DimensionAttributeValue dimAttributeValue; DimensionAttributeValueCombination dimAttributeValueCombo; VendLedgerAccounts vendLedgerAccounts; List notSelectedFieldList = new List(Types::Container); recId defaultAccountHierarchyId = DimensionHierarchy::getHierarchyIdByHierarchyType(DimensionHierarchyType::DefaultAccount); recId mainAccountDimAttribute = DimensionAttribute::getMainAccountDimensionAttribute(); // Allow all posting types, so long as they are not closed // Only add the combination if it doesn't exist or doesn't exist as a ledger dimension on the vendLedgerAccounts table while select MainAccountId, Name, Type from mainAccount order by MainAccountId where mainAccount.LedgerChartOfAccounts == LedgerChartOfAccounts::current() && mainAccount.Type != DimensionLedgerAccountType::Total outer join RecId from dimAttributeValueCombo where //dimAttributeValueCombo.DisplayValue == mainAccount.MainAccountId && //original code dimAttributeValueCombo.MainAccount == mainAccount.RecId && //modified Code dimAttributeValueCombo.LedgerDimensionType == LedgerDimensionType::DefaultAccount outer join RecId from vendLedgerAccounts where (vendLedgerAccounts.SummaryLedgerDimension == dimAttributeValueCombo.RecId || vendLedgerAccounts.ClearingLedgerDimension == dimAttributeValueCombo.RecId || vendLedgerAccounts.PurchasingLedgerDimension == dimAttributeValueCombo.RecId || vendLedgerAccounts.PurchasingOffsetLedgerDimension == dimAttributeValueCombo.RecId) notexists join dimAttributeValue where dimAttributeValue.DimensionAttribute == mainAccountDimAttribute && dimAttributeValue.EntityInstance == mainAccount.RecId && (dimAttributeValue.IsSuspended == true || dimAttributeValue.IsBlockedForManualEntry == true) { if (!vendLedgerAccounts) { notSelectedFieldList.addEnd([mainAccount.MainAccountId, mainAccount.Name, mainAccount.Type]); } } return notSelectedFieldList; } Disclaimer: This programming example is for illustration purposes only. Microsoft disclaims all warranties and conditions with regard to use of the programming example for other purposes. Microsoft shall not, at any time, be liable for any special, direct, indirect or consequential damages, whether in an action of contract, negligence or other action arising out of or in connection with the use or performance of the programming example. Nothing herein should be construed as constituting any kind of warranty. --author:Mansour Yahya Mohamad Mansour Источник: http://blogs.msdn.com/b/axsupport/ar...-accounts.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
