Старый 24.02.2012, 23:13   #1
emeadaxsupport: Fixed Dimension Support in AX2012
Источник: http://blogs.msdn.com/b/axsupport/ar...in-ax2012.aspx
AX 2012 has provided a new dimension framework that includes
a shared chart of accounts and system-backed financial dimensions. The concept
commonly known as ‘Fixed dimensions’ available in releases prior to AX 2012 is supported
differently in the new framework.
1. If your scenario is to fix a dimension value to
“Blank” for a specific account prior to AX 2012, the new account structure
functionality will provide this support. Account structures are used to
determine the valid combinations of main account and financial dimension values
that should be posted to a general ledger account. You can create multiple
account structures that can be used by a chart of accounts. For example, you
may have 2 different account structures such as this:
Balance Sheet Segments included: Main Account+ Department
Profit and Loss Segments included: Main Account + Department + Cost Center
This setup will ensure that CostCenter is not available when recording entries against any of the main accounts
that are defined in the range for the Balance Sheet account structure.
2. If your scenario is to fix a dimension value to
a specified value for a specific account prior to AX 2012, you can set up the
main account as an allocation account and define the allocation terms
destination to be to the specific dimension value. When recording an entry
against this account, the posting to general ledger will include this dimension
value.
For example, I want a specific cash account to always be posted with Department “001” but the offsetting profit and
loss account may be posting to other department values. By selecting the main
account (General ledger > Setup > Chart of accounts > Chart of
accounts), and then selecting to view the main account for a specific company,
select the “Allocation” checkbox in the general tab. The Allocation terms
button will be enabled and you can select to define the allocation terms.
Assuming my cash account number is 110020, and my account structure for this account is Main Account + Department,
my allocation term would look like this:
Percent allocation: 100.00
Source financial dimension criteria:
Department: Unspecific (this means
that this rule is in play no matter what department value is entered on the
document)
Destination ledger account:
To account: 110020
To financial dimensions:
Department: 001
This setup would then always post to department 001 when posting to main account 110020 for the specified
company.
3. If your scenario is to fix a dimension value to a specified value for a specific account prior to AX 2012 because the dimension
value is representing a sub account, you have another option. You can set up
the main account number to include the dimension value instead of using a
dimension. For example, using the cash account above, the main account number
could be 110020001.
emeadaxsupport: Measure 'Total purchases' in Accounts payable cubes for dimension 'Vendor Master' shows values Uknown Blog bot DAX Blogs 0 01.03.2011 22:11
emeadaxsupport: Microsoft Dynamics AX 2012 announced and discontinuation of support for Oracle Blog bot DAX Blogs 0 20.01.2011 17:11
emeadaxsupport: OLAP Time dimension does not contain dates for year 2011 Blog bot DAX Blogs 0 07.01.2011 20:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 06:16.
