Старый 06.01.2012, 01:13   #1
AIF: Decoding image blobs obtained from OData query services
Источник: http://blogs.msdn.com/b/aif/archive/...-services.aspx
This post on the OData Query Service is by Principal Software Architect Arthur Greef.
Images retrieved using OData query services are returned as base 64 encoded containers. The following code will decode the image container into a byte array that contains just the image.
string base64EncodedString = "";
byte[] serializedContainer = Convert.FromBase64String(base64EncodedString);
byte[] modifiedSerializedContainer = null;
if (serializedContainer.Length >= 7 &&
serializedContainer.Take(3).SequenceEqual(new byte[] { 0x07, 0xFD, 0x30 }))
modifiedSerializedContainer = serializedContainer.Skip(7).ToArray();
File.WriteAllBytes("", modifiedSerializedContainer);
AIF: OData Query Service Blog bot DAX Blogs 0 24.08.2011 09:11
AIF: Microsoft Dynamics AX 2012 Services and AIF White Papers Blog bot DAX Blogs 0 16.06.2011 00:11
axinthefield: The AIF processing services used by each of the AIF adapters in AX 2009 Blog bot DAX Blogs 0 27.05.2011 05:12
daxdilip: Contd...Scaling out AIF Services via Virtual IP Load Balancer Blog bot DAX Blogs 0 12.04.2011 15:11
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
Часовой пояс GMT +3, время: 03:35.
