Старый 14.12.2011, 04:27   #1
sumitsaxfactor: Find Active Dimensions for a Legal Entity [Ax2012]
Источник: http://sumitsaxfactor.wordpress.com/...entity-ax2012/
This article focuses on getting the active dimensions for a Legal Entity. In Ax 2009, we could get the number of dimensions by using the enumCnt method on SysDimension enum and get the count. Here it is not that straight forward.
Following job will help you in getting the count and display their names;
staticvoid getActiveFinancialDimensions(Args _args)
    DimensionAttributeSetItem   dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger
    DimensionAttribute          dimAttr; // Contains the financial dimensions records
    DimensionEnumeration        dimensionSetId; //Record id for table that contains active dimensions for current ledger
    int dimAttrCount;
    //Get the record Id (dimension set id) for current ledger to find active dimensions
    dimensionSetId = DimensionCache::getDimensionAttributeSetForLedger();
    //Find the count of active dimensions for current ledger except main account
    selectcount(RecId) from dimAttr
            where dimAttr.Type != DimensionAttributeType::MainAccount
        join RecId from dimAttrSetItem
            where dimAttrSetItem.DimensionAttribute == dimAttr.RecId &&
                dimAttrSetItem.DimensionAttributeSet == dimensionSetId;
    info(strFmt("Total active financial dimensions for current legal entity: %1", dimAttr.RecId));
    //Find all the active dimensions for current ledger except main account and display them
    whileselect * from dimAttr
        orderby Name
        info(dimAttr.Name);
sumitsaxfactor: Ledger Accounts and Financial Dimensions Blog bot DAX Blogs 0 13.12.2011 22:11
Microsoft Dynamics CRM Team Blog: How to enable an entity to use Activity Feeds solution Blog bot Dynamics CRM: Blogs 0 10.11.2011 04:19
sumitax: AX2012 Features – Financial Dimensions changes Blog bot DAX Blogs 0 12.05.2011 15:11
Daniel Cai: MSCRM 4.0: Recover "Create New" Button for the Associated View of an Invoiced/Active Contract Record or an Inactive Record of CRM Custom Entity Blog bot Dynamics CRM: Blogs 0 02.07.2010 05:23
Часовой пояс GMT +3, время: 16:55.
