Старый 10.10.2011, 17:11   #1
emeadaxsupport: How to remove notifications (EventInbox) older than one month
Источник: http://blogs.msdn.com/b/emeadaxsuppo...one-month.aspx
In previous post the solution was to run batch job Administration > Periodic > Notification clean-up as a part of your maintenance plan. Now we have follow up question: how to set up this batch job to remove messages older than 1 month.
To achieve it we can use static function monthRange (public static str monthRange(int relativeMonthsFrom = 0, int relativeMonthsTo = 0)) of class SysQueryRangeUtil. So now we can schedule Notification clean-up to run every month with following parameters:
It will delete all notification between 2 month ago till 1 month ago
--author: Czesława Langowska
--editor: Czesława Langowska
--date: 10/Oct/2011
emeadaxsupport: Printer defaults to letter instead of A4 - how AX finds the default printer Blog bot DAX Blogs 0 27.04.2011 22:11
emeadaxsupport: How to add financial dimension to Dynamics AX Default cubes Blog bot DAX Blogs 0 13.01.2011 16:11
emeadaxsupport: How to troubleshoot Enterprise Portal error ”Unable to render content due to an error. Please contact your system administrator." Blog bot DAX Blogs 0 17.11.2010 18:11
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
Часовой пояс GMT +3, время: 07:42.
