Старый 20.09.2011, 23:12   #1
workflowax: The Request Failed with HTTP status 401: Unauthorized
Источник: http://workflowax.wordpress.com/2011...nauthorized-2/
I’ve been battling through “fixing” a clients Workflow setup. Its been working for the last while but just stopped all of a sudden. I tried to validate the workflow website and received the message “The Request Failed with HTTP status 401: Unauthorized”. I went through some of the suggestions made by Amer over at his blog to fix the error before reviewing the server name specified for the workflow website. It happened to be set to the server’s IP address, after changing this back to the valid server name all was well!
E..G:
Old: http://10.0.0.1:80/MicrosoftDynamicsAXWorkflow50
New: http://CLIENTAOS_SERVER:80/Microsoft...csAXWorkflow50
I hope this helps somebody.
The request failed with HTTP status 405: Method Not Allowed. Poleax DAX: Администрирование 1 07.06.2011 13:29
emeadaxsupport: Unable to validate workflow URL in AX 2009 - Get the following error: The request failed with HTTP status 405: Method Not Allowed Blog bot DAX Blogs 0 07.07.2010 23:05
Ronald Lemmen: Exception while trying to execute AsyncOperationId: The request failed with HTTP status 401: Unauthorized. Blog bot Dynamics CRM: Blogs 0 10.11.2009 21:05
Ошибка 401: Unauthorized в отчетах Савран Роман Dynamics CRM: Администрирование 12 16.04.2009 10:26
The request failed with HTTP status 400: Bad Request ZooY Dynamics CRM: Разработка 3 11.08.2008 08:09
Часовой пояс GMT +3, время: 02:11.
