Старый 03.08.2011, 09:11   #1
crminthefield: CRM 2011 Outlook Client Configuration - XML Configuration File Tip
Источник: http://blogs.msdn.com/b/crminthefiel...-file-tip.aspx
If you're attempting a command line CRM 2011 Outlook client installation using an XML configuration file, you may run into the following error:
12:12:46| Info| Client Configuration Wizard Running Mode : Silent
12:12:47| Error| Exception : Sequence contains no matching element at System.Linq.Enumerable.First[TSource](IEnumerable`1 source, Func`2 predicate)
at Microsoft.Crm.Application.Outlook.Config.ClientConfig.AddDeployment(DeploymentsDeployment[] deployments, AuthUIMode uiMode)
at Microsoft.Crm.Application.Outlook.Config.ClientConfig.Run(Boolean runInsideOutlook)
at Microsoft.Crm.Application.Outlook.Config.ClientConfig.Start(String[] args, Boolean runInsideOutlook)
12:12:47|Verbose| Method entry: Microsoft.Crm.Application.Outlook.Config.ClientConfig.Terminate
12:12:47| Info| Exit code: Failure
12:12:47|Verbose| Method exit: Microsoft.Crm.Application.Outlook.Config.ClientConfig.Terminate
This error message most likely indicates that a portion of your configuration file is not set correctly. The most common cause of this error message is because the syntax of your organization is not exactly correct. You either have the wrong organization name listed, or the case sensitivity is off. I've listed an example of an XML configuration file below:
http://crmserver
JSorg
The line in question would be:
JSorg
Technically, this line is asking for the following:
OrganizationUniqueName
To obtain your OrganizationUniqueName, navigate to the following area within your CRM 2011 application:
  • Settings - Customizations - Developer Resources
Once here, you'll find your Organization Unique Name value. This value is case sensitive! Once you use the correct OrganizationUniqueName within your XML configuration file, you should be good to go.
- Jon
crminthefield: CRM Outlook Client - Network/Bandwidth Concerns Blog bot Dynamics CRM: Blogs 0 25.07.2011 22:11
crminthefield: Microsoft Dynamics CRM 2011 Custom Contact Entry Website using Early-Bound entity Classes. Blog bot Dynamics CRM: Blogs 0 04.06.2011 08:16
crminthefield: CRM 4.0 Outlook Client has Grayed Out Filters with CRM 2011 Server Blog bot Dynamics CRM: Blogs 0 05.05.2011 15:11
Часовой пояс GMT +3, время: 03:25.
