Старый 15.06.2011, 11:11   #1
Ronni Mattsson: SharePoint 2010 – Developer Dashboard
Источник: http://blogs.msdn.com/b/microsoft_dy...dashboard.aspx
Do you sometimes feel that you have no idea about why AX is slow on EP and what is going on?
Please look at the SharePoint 2010 Develop Dashboard, which can give you some information of which web app is using the most time.
http://blogs.technet.com/b/patrick_h...dashboard.aspx
Happy hunting.
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Muhammad Ali Khan: Using Business Connectivity Services(BCS) In SharePoint 2010 For Connecting To MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 25.01.2010 01:08
Muhammad Ali Khan: Business Connectivity Services (BCS) Using WCF & SharePoint Designer 2010 Blog bot Dynamics CRM: Blogs 0 12.01.2010 04:44
Мелкомягкий CRM: Панель управления для MS CRM с помощью Reporting Services Blog bot Dynamics CRM: Blogs 1 24.08.2009 14:41
Часовой пояс GMT +3, время: 01:45.
