Старый 18.05.2011, 12:11   #1
axblog4u: X++ Script to renamePrimaryKey across companies
Источник: http://axblog4u.wordpress.com/2011/0...oss-companies/
Hey Guys
During data upgrade to AX2012 we had issue in ‘Product Upgrade’ preprocessing checklist. Validation errors were observed due to presence of same item in different companies with different ‘DimGroupId’ or ‘ItemType’ values.
Only way left to resolve the issue was by renaming the ‘ItemId’ of these items. So we renamed all the items which are of type ‘StopItem’ to ‘%Old Item Name’.
Accordingly the String size of ‘itemIdBase’ and ‘EcoResProductNumber’ EDTs were increased to 30 to avoid the truncation of ‘ItemId’ and ‘ProductNumber’.
The best option left to optimize the work load instead of manually updating the item was to use the renamePrimaryKey method.
static void renamePKInventTable()
    #File
    #define.prefixItem('Old')
    InventTable     inventTable;
    container       getCompanyList;
    int             i;
    DataAreaName    id;
    container getCompany()
        dataArea  dataArea;
        // Virtual Companies should not be added.
        while select dataArea
            where dataArea.isVirtual != NoYes::Yes
            getCompanyList += [dataArea.id];
        return getCompanyList;
    getCompanyList = getCompany();
    for(i = 1; i<= conlen(getCompanyList); i++)
        id = conpeek(getCompanyList, i);
        changeCompany(id)
            inventTable.clear();
            while select inventTable
              where inventTable.RMCItemType == RMCItemType::StopItem
                 && inventTable.dataAreaId  == id
                 && !(inventTable.ItemId like 'Old*')
                ttsbegin;
                inventTable.ItemId = #prefixItem +
                                     #delimiterSpace +
                                     inventTable.ItemId;
                inventTable.renamePrimaryKey();
                if(inventTable)
                    inventTable.selectForUpdate(boolean::true);
                    inventTable.ItemName  = inventTable.ItemId;
                    inventTable.NameAlias = inventTable.ItemName;
                    inventTable.update();
                ttscommit;
This X++ script renamed all the Items in Item Master across companies except the virtual company;)
Последний раз редактировалось Poleax; 18.05.2011 в 14:01. Причина: оформление
renameprimarykey
axblog4u: Multiple XPO Import Version – 2 Blog bot DAX Blogs 0 25.01.2011 22:11
axblog4u: Form Size Exceeds the Maximum Pixel in Dynamics AX Blog bot DAX Blogs 0 23.01.2011 10:12
mscrm4ever: CRM Form Script Loader Blog bot Dynamics CRM: Blogs 0 21.04.2009 04:07
Часовой пояс GMT +3, время: 01:46.
