Старый 30.03.2011, 18:11   #1
waikeatng: Create Alert using X++ codes
Источник: http://waikeatng.blogspot.com/2011/0...g-x-codes.html
Sometimes Infolog message is not sufficient enough for prompting information to users. It is possible to create alert message using code as an alternative. It is fairly simple to create alert message manually by just inserting a new record in EventTable where all the alert messages are stored. Below is a code snippet for creating alert using code in AX 2009.
static void CreateAlertUsingCode(Args _args)
    EventInbox          inbox;
    inbox.initValue();
    inbox.ShowPopup     = NoYes::Yes;
    inbox.Subject       = "This is the Alert subject";
    inbox.Message       = "This is the Alert message";
    inbox.AlertedFor    = "This alert is just information no links are available";
    inbox.SendEmail     = false;
    inbox.UserId        = curuserid();
    inbox.TypeId        = classnum(EventType);
    inbox.AlertTableId  = tablenum(Address);
    inbox.AlertFieldId  = fieldnum(Address, Name);
    inbox.TypeTrigger   = EventTypeTrigger::FieldChanged;
    inbox.CompanyId     = curext();
    inbox.InboxId       = EventInbox::nextEventId();;
    inbox.AlertCreatedDateTime = DateTimeUtil::getSystemDateTime();
    inbox.insert();
emeadaxsupport: Possibilities to create Memory Dumps from crashing processes Blog bot DAX Blogs 0 12.05.2010 19:05
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Ruslan Goncharov: A few words about sorting codes Blog bot DAX Blogs 0 18.02.2009 21:05
jerry-dynamics: tax codes Blog bot DAX Blogs 0 16.06.2007 11:20
Часовой пояс GMT +3, время: 07:21.
