Старый 18.03.2011, 20:11   #1
workflowax: Some pointers on developing your own ledger journal workflows
Источник: http://workflowax.wordpress.com/2011...nal-workflows/
I did a couple of developments on ledger journal workflows a while ago and wrote down these pointers for myself to remember when doing it again.
1) Remember that your workflow must be linked to the same module / workflow category that the journal you wish to workflow is linked to i.e Customer, Vendor or Ledger
2) The template that is used for each LedgerJournalType must be defined in the LedgerJournalWFApprovalTemplates macro. (examined from: LedgerJournalName::findJournalTemplate)
workflowax: Workflow Session at Dynamics AX 2012 Technical Conference Blog bot DAX Blogs 0 08.02.2011 18:11
Preston.Larimer: Item import from CSV file made easy (Kinda) Blog bot DAX Blogs 3 15.11.2010 12:26
workflowax: Importing workflows – Configuration IDs Blog bot DAX Blogs 0 07.09.2010 13:05
workflowax: Developing a business connector application Blog bot DAX Blogs 0 25.05.2010 23:05
C# and AX Development: Posting a ledger journal Blog bot DAX Blogs 0 17.03.2009 19:05
Часовой пояс GMT +3, время: 19:54.
