#1 |
dynamicsaxbi: Understanding How Many SSRS Reports come with Dynamics AX 2012
Источник: http://blogs.msdn.com/b/dynamicsaxbi...s-ax-2012.aspx
============== This is a common and simple question we get often, so let’s take the opportunity to answer it clearly now. First, a warning : keep in mind that all the numbers below are approximate – but overall the are accurate enough to have a meaningful discussion. Let’s start with a quick recap of the portfolio of reports in Dynamics AX 2009 included:
Again the 850 number is approximate but relatively close to the final count. Why are there fewer total production reports in AX 2012 than in AX 2009? Simple answer: A lot of the MorphX reports we shipped in previous AX release were NEVER BEING USED so we decided not to keep them going forward to AX 2012. Watch our latest YouTube video that discusses the data we collected for some greater insight into what we found out about MorphX report usage. A second factor is that some MorphX reports were merged. We took advantage of the interactive features of SSRS to replace two or more MorphX reports with a single SSRS report. A third thing to keep in mind is that some reports were simply not needed even if they were used. For example, if a List Page was available and an equivalent MorphX report existed with the same data we often simple removed the report, preferring that the users should simply print the List Page. Источник: http://blogs.msdn.com/b/dynamicsaxbi...s-ax-2012.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
#2 |
MCT
Давно пора и как следствие уже не нужен будет пакетный сервер отчетов в ax.
Axapta book for developer |
#3 |
А как это будет работать с настройками печати для документов? те же количества копий и т.п. - все это останется?
Ivanhoe as is.. |
