Старый 23.02.2011, 14:11   #1
daxdilip: Question - How to Scale out AIF WebServices via Load Balancer
Источник: http://daxdilip.blogspot.com/2011/02...e-out-aif.html
We have a load-balanced environment where we have 6 AOSServers in a clustered environment each hosting AIF Webservices on IIS.
The Load Balancer is basically a virtual IP which routes the requests to the 6 AOS Servers depending on the load. Now, when we try to consume the AIF Services hosted on the 6 boxes through the Load Balancer, the request doesn't go through, but when we try to consume the AIF Services directly from one of the 6 boxes, it works fine.
How do we make the request work through the load balancer? Anyone has any ideas or experienced this before, Please post your comments. Thanks.
P.S - Googled it, and this link at the end talks about the inherent limitation which AIF WebSercvice has as it has 1:1 relationship with the IIS website http://www.eggheadcafe.com/software/...aling-out.aspx
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
daxdilip: AIF Error creating the Web Proxy specified in the 'system.net/defaultProxy' configuration section. Blog bot DAX Blogs 0 29.12.2010 18:11
emeadaxsupport: How to trace AIF Web service SOAP message Blog bot DAX Blogs 0 06.12.2010 16:11
daxdilip: Tip How to Trace a Call to an AIF Web Service Blog bot DAX Blogs 0 26.11.2010 00:12
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer Blog bot DAX Blogs 0 06.05.2010 03:16
Часовой пояс GMT +3, время: 04:52.
