Старый 18.02.2011, 17:11   #1
sumitax: AX2009 – Best Practice Check for Classes
Источник: http://sumitax.wordpress.com/2011/02...k-for-classes/
During my current Project , while doing code review we found the following Best practice for Classes .These BP checkswill be useful in othe Project so I will include a list here :
  1. Make sure Class has a construct method , the standard one that is present for all AX Classes.
  2. Do not write to variables passed in  a Class method as Parameter. Typically values passed in parameter are for read purpose and writing to those variables is not recommeded and gives a BP Deviation warning.
  3. All the label Ids used in X++ code should be enclosed in double quotes as specifying them in single quotes is a BP Deviation warning.
sumitax: AX2009 EP – Disabling postbacks on Blog bot DAX Blogs 0 13.12.2010 21:12
sumitax: Creating new GUID in AX2009 Blog bot DAX Blogs 0 17.11.2010 18:11
sumitax: SharePoint 2010 and AX2009 Blog bot DAX Blogs 0 11.11.2010 11:11
sumitax: Workflow Installation Steps -AX2009 Blog bot DAX Blogs 0 14.10.2010 23:06
sumitax: Ax2009 Programming – Getting Started book Blog bot DAX Blogs 0 13.08.2010 21:06
Часовой пояс GMT +3, время: 23:35.
