Старый 24.01.2011, 20:11   #1
ukax: Application Integration Framework (AIF) Document Services Workshop
Источник: http://blogs.msdn.com/b/ukax/archive...-workshop.aspx
Hi All,
I’m pleased to announce a Microsoft Dynamics AX2009 - Application Integration Framework (AIF) Document Services Workshop will be running on March 21st and 22nd. The following is a brief agenda of what the session will be covering:
Summary:
- Architecture & administration
- Configuration of AIF for file adapter
- Creating a sales order via file adapter
- Customising a sales order and deploying changes to AIF
- Moving AIF development between environments
- AIF message format
- Configuration of AIF web services
- Creating a sales order via web services
- Deploying changes between environments
- Debugging
- Demonstration of using the AX Adapter for BizTalk Server 2009
- Known issues and troubleshooting steps
The session will walk through the steps required to configure AIF message processing using the file adapter and web services, including all aspects expected during the lifecycle of an AIF implementation: installation and configuration, development, deployment and troubleshooting.
Attendee profile:
Partner technical consultants or developers that have NOT yet implemented their first AIF based solution.
Duration:
2 days
The registration link for the workshop is as follows:
https://training.partner.microsoft.com/learning/app/management/RegistrationEx/LMS_Registration.aspx?UserMode=0&ActivityId=727278&CallerURL=%2flearning%2fapp%2ftaxonomy%2flearnerSearch%2fLearnerSearch.aspx%3fUserMode%3d0
Thanks
Andrew
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
Kashperuk Ivan: How to quickly set up Application Integration Framework (AIF) for testing Axd documents Blog bot DAX Blogs 0 07.11.2009 14:05
Dave: AIF Configuration and Additional Findings Blog bot DAX Blogs 1 04.11.2009 17:29
Microsoft Dynamics AX 2009 White Paper: Application Integration Framework (AIF) BizTalk Adapter Configuration for Data Exchange, Part II - English Vadik DAX: База знаний и проекты 0 14.04.2009 09:36
Dynamics AX: Dynamics AX 4.0 - Application Integration Framework - Overview Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 12:53.
