Старый 06.10.2010, 13:05   #1
axhelper: Jump between InterCompany order lines
Источник: http://feedproxy.google.com/~r/AxHel...der-lines.html
This is a basic job that describes how you can jump from one order line to another in the intercompany order structure.
In this example I have created an intercompany order that also has a linked purchase order in the production company to a vendor. This is one way you can use to jump up between the linked order lines.
I start out in the sales company “FO1” and go all the way up to the intercompany sales line in the production company “FO”, then I change company to “FO” so that I can gain access to the production company’s purchase line. From this purchase line I change the direction and move all the way back to the original sales line that is located in the sales company FO1.
As you can see I run the code while being in the sales company “FO1″. I start out with a specific sales line that I get by searching for its RecId. This code it meant to be run with a sales line as its basis. Preferably from the SalesTable form, the SalesLine table or some other object where you have sales line data that you want to explore.
static void FO_InterCompanyRefs(Args _args)
SalesLine salesLine =
SalesLine::findRecId(5637552101),
icSalesLine = null;
PurchLine purchLine,
icPurchLine;
// Sales company = FO1
// Production company = FO
// Original Sales Company SalesLine
print salesLine.SalesId;
print salesLine.ItemId;
print salesLine.dataAreaId;
print "------------------";
purchLine =
PurchLine::findInventTransId(
salesLine.InventRefTransId);
// Sales Company PurchLine
print purchLine.PurchId;
print purchLine.ItemId;
print purchLine.dataAreaId;
icSalesLine =
purchLine.interCompanySalesLine();
// Production company SalesLine
print icSalesLine.SalesId;
print icSalesLine.ItemId;
print icSalesLine.dataAreaId;
changecompany(icSalesLine.dataAreaId)
purchLine = PurchLine::findInventTransId(
icSalesLine.InventRefTransId);
// Production company PurchLine
icSalesLine =
SalesLine::findInventTransId(
purchLine.InventRefTransId);
purchLine =
icSalesLine.interCompanyPurchLine();
salesLine =
purchLine.interCompanySalesLineOriginal();
pause;
sumitax: Intercompany – automatic purchase order creation Blog bot DAX Blogs 0 28.09.2010 16:05
palleagermark: It is possible for users to edit the Item reference fields of sales order lines and purchase order lines. Blog bot DAX Blogs 0 17.02.2010 21:07
palleagermark: Annoying bug in AX 2009 Intercompany Sales Order Blog bot DAX Blogs 0 21.01.2010 11:05
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
DynamicsAxSCM: Changes in Sales and Transfer Order Picking from Microsoft Dynamics AX 4.0 to Dynamics AX 2009 Blog bot DAX Blogs 0 18.05.2009 02:05
Часовой пояс GMT +3, время: 06:53.
