Старый 10.08.2010, 02:07   #1
Dynamics AX Sustained Engineering: Date\time data reflected in User's preferred time zone after conversion from UTC
Источник: http://blogs.technet.com/b/dynamicsa...-from-utc.aspx
Scenario
When running reports that contain date\time information that is stored in the database in UTC format the reports are showing the user's preferred time zone instead of the company's specified time zone.
Resolution
To display the timezone information in the company timezone instead of the user's perferred time zone, you can change the setText method (Example from \Reports\HRMCourseAttendeeStatusList):
void setText()
periode.text(strfmt("@SYS53184", date2StrUsr(DateTimeUtil::date(hrmCourseTable.StartDateTime), DateFlags::FormatAll),
date2StrUsr(DateTimeUtil::date(hrmCourseTable.EndDateTime), DateFlags::FormatAll)));
To:
periode.text(strfmt("@SYS53184", date2StrUsr(DateTimeUtil::date (DateTimeUtil::applyTimeZoneOffset(hrmCourseTable.StartDateTime, DateTimeUtil::getUserPreferredTimeZone())), DateFlags::FormatAll),
date2StrUsr(DateTimeUtil::date (DateTimeUtil::applyTimeZoneOffset(hrmCourseTable.endDateTime, DateTimeUtil::getUserPreferredTimeZone())), DateFlags::FormatAll)));
jinx: Dynamics AX AIF Webservices – Date, Time und Datetime Datentypen Blog bot DAX auf Deutsch 0 12.06.2010 01:05
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 11:34.
