Старый 19.07.2010, 22:06   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Microsoft Dynamics AX 2009 White Paper: Cost Management
Overview
Microsoft Dynamics AX 2009 allows a very flexible configuration of the Inventory management, Production, Accounts payable, Accounts receivable, and Master planning modules, which all indirectly affect cost management. This flexibility increases the complexity of the application, because the various parameter settings might result in many potentially complex cost management scenarios.
This white paper provides insight into cost management in Microsoft Dynamics AX 2009, and provides a better understanding of the consequences of some of the choices that have been made in the implementation and setup of Microsoft Dynamics AX 2009 for cost management. The following information is discussed:
  • Inventory evaluation methods
  • Inventory calculation
  • Recommended parameter settings
  • Change inventory dimension group for an item
  • Create ledger accounts to represent inventory in the chart of accounts
  • Change an item type
  • Change an item group
  • Marking
  • Ledger reconciliation
  • Database logging cost parameters
-ТСЯ или -ТЬСЯ ?
Старый 19.07.2010, 22:59   #2
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,342 / 3563 (125) ++++++++++
2Vadik: А ссылочку-то и забыл: http://www.microsoft.com/downloads/d...displayLang=en
За это сообщение автора поблагодарили: Vadik (1).
Старый 19.07.2010, 23:16   #3
Vadik is offline
Vadik
Аватар для Vadik
А ведь неделя только началась.. Спасибо, добавил ссылку
Изображения
-ТСЯ или -ТЬСЯ ?
ax2009, документация, скачать (download)
Microsoft Dynamics AX 2009 White Paper: Print Management Integration Guide Vadik DAX: База знаний и проекты 5 06.05.2009 13:59
gl00mie: Dynamics AX 2009 Guides and White Papers Blog bot DAX Blogs 0 13.08.2008 20:09
Часовой пояс GMT +3, время: 04:19.
